My engine harness is cut before the ignition coil/transistor and resistor&condenser and I can't figure out how to wire it correctly even after following the FSM wiring diagrams. The three components are sort of bridged together and i wired it as the diagram says but i think there is a weird trick wiring in the original harness/plugs...
I'm not getting any spark because of this and im sure 12v is going into the coil and the grounds are good but nothing is coming out what so ever. Im thinking maybe i have the signal wire that comes from the ecu wired wrong (white wire)? any help would be appreciated.
Also the chassis is an 89' coupe. ka24de motor swapped in from a 91' hatch
