HELP KA_T
mikey0129
Car: dwadawdwad
hey guy im new to turboing a 240sx
i have a 1993 s13 dohc and wanting to turbo it out
i wanted to go with the cheap turbo route since im not a baller
so help me out guys
i was thinking... all this items r from fat boy garage in ebay
Bottom mount t25 turbo
turbo manifold
turbo elbow pipe
those 3 items with gasket and screws are $400
and ebay frontmount intercooler with pipings are $200
like oil lines returnlines etc $100
I heard of people just putting this on a stock injectors and stock maf and stock ecuWhould this setup work with stock maf,ecu,injectors and no tuning ?Can i just slap dis on and make it run ? im prob not ganna mess with any boost lvl ill prob have like 7-8 starting right?and if i wanted more power den i could change out all the injectors,ecu,maf right?
This is my daily driving car so im not ganna be pushing krxy hp THX for all the help guys
boznuttz
Car: MS13
At 7 pounds of boost on a stock T25, you will NEED some sort of fuel management. You can use the stock injectors, ecu, and MAF.
The stock MAF is good to 250 whp.The stock injectors can be used up to around 200 whp.As for using the stock ecu for timing, you won't be running high boost, and timing will pretty much rely on your knock sensor, lol.... the again, a lot of T25 guys are simply running an SAFC and Wideband setup without much for timing....but anything over 8 psi or so in my opinion...is a little much for the stock ecu. You could always invest in an MSD BTM down the road as well.
A stock T25 at 7 psi is a decent setup, lol. So it all depends on what route for fuel management you would like to go. An SAFC and Wideband O2 is a proven and true setup. You could also use an FMU. 8:1 could be your best bet. You can find one for around 100~200 online.
mikey0129
Car: dwadawdwad
wats a fmu?
boznuttz
Car: MS13
Fuel Management Unit or Rising Rate Fuel Pressure Regulator.
An FMU works on the principal that for each pound of boost, it increases pressure in the fuel rail. An 8:1 operates such as for each Pound of boost, it will increase pressure on the fuel rail 8 pounds. Stock pressure on a KA24DE is 38 to 43 on vacuum as long as the stock fpr is in check.
Of course you will need to upgrade your stock fuel pump and such.
