drape123 »
https://forums.nicoclub.com/drape123-u33485.html
Wed Feb 22, 2006 9:18 pm
okay, after hooking up my boost gauge and seeing that im only getting 7psi of boost, i wanted to get to the bottom of this.
so i hooked up my consult device and noticed im getting the dreaded error 34 (knock sensor circuit)
so i looked under the hood and i guess whoever did the conversion, never hooked up the knock sensor because the connector from the sensor is just dangling there and i cant find the other side that connects to the ecu.
so i was wondering, does anybody know here which wire it is on the ECU to the knock sensor? i believe it is pin 23 but i want to be sure. and do i just ground the 1000k ohm resistor to pin 23? want to see if this trick works, then if it does i'll go buy a knock sensor and wire it myself.
TIA
