Simmsled »
https://forums.nicoclub.com/simmsled-u3103.html
Fri May 12, 2006 1:46 am
Like poormanQ45 said, could be a loose wire touching somewhere. I would check the ground wire at the head unit. The unit will still work and pass low level (rca) output when the ground wire comes off but not pass high level (onboard amp) power because it draws much more power than low level (rca) output. Make sure that the ground off of your pioneer deck is grounded TO THE METAL OF THE CAR and not to the wire harness. The factory ground in the wire harness is not good. check that and get back to us!
