RFcool »
https://forums.nicoclub.com/rfcool-u27691.html
Tue Apr 24, 2007 4:38 pm
coilpacks are all good on the car. wiring harness seems all good, double checked it all. ignition switch has been changed. It fires and runs now, but it seems as though the 2nd spark plug on the passenger side is firing properly. The spark plug wasnt wet and not even the new one we put in changed. used a spark plug tester and its all good but it doesnt seem as though the fuel injector is working or it is clogged right there. So i might i think have to change the injectors out. And the final thing is when the car runs, it doesnt turn off. You litteraly can have the car on and running and go to turn it off with the key out of the ignition and it's still running. You have to pull the ignition relay out from under the hood to shut it off. I had a friend in Peoria, Illinois who had the same problem after doing an RB26dett swap in his TT. And he is a very seasoned vet when it comes to working on TT's. He took out his ASH-Spec ECU the same one i have and put in a standard stock one and boom it turned the car off. Weird stuff. I really miss my 240's they are much easier than these engines. everyone tells me once i get this thing running properly that i wont want to go back, but at this point im getting close to throwing in the towel. There isnt a single shop in town here willing to work on this car let alone any mechanics at our nissan that really know what they are doing on this car, and they told me that themselves. So thanks so far to everyone for the suggestions and i might give you a call if you dont mind.
