Blazin Hondas »
https://forums.nicoclub.com/blazin-hondas-u3479.html
Thu Jan 09, 2003 6:34 am
Hey all, I need help with my 91 s13, 170k on it. Ok, when I start the car the motor idles at 1100 rpm, then I give it a little stab, to about 1500 rpm, then the idle drops to stock 700. After it starts to get a little warm ( before the temp gauge moves) when I pump a little throtle into it, as the tach comes down it studders to about 100 rpm, sometimes stalls. It starts right back up though. I can smell gas with the windows down. I think its coming from the Exhaust. It also fouls the plugs quickly, about 300 mi they get heavy carbon build up. Also, just did the oil chang, and it smelled like gas. Is that normal? One more thing, When I hit the brakes it drops RPM. It kinda sounds like Vacume leak, but it holds vac pressure on the gauge. It cracked the Brake booster line a while ago. But I replaced it. Any Thoughts? All the help Is apreciated.
I live in Corona, CA now, but I used to live in Pasadena,CA , it did it there too.
