Help - is this an SR or CA down pipe?
trevr
Car: '07 Mitsubishi Eclipse V6 swapped supercharged
'93 Nissan 240SX Vert CA18det **SOLD**
Can anyone tell by looking at the flange degree say whether this pipe was intended for an SR or CA outlet pipe?
I bought this over the winter and thought I purchased an SR downpipe to match an SR20 outlet pipe, but they conflict. I'm using SSAC manifold, big t25g, and the sr20 outlet pipe, but when mated, the downpipe veers out under the driver side door missing the rest of the exhaust.
Thanks for any help.
sjbsuperman1425
Car: 1989 Nissan 240sx
CA18DET
if you have an SR20 O2 housing, and this doesn't work (goes under the trans when bolted up) its a CA downpipe :D
trevr
Goes the other way... comes out under the driver door.
From what I've been reading.. if you are using CA o2 housing and SR down pipe it goes under the transmission. But if you are using SR o2 pipe and CA down pipe it goes under the drivers door.
I found an old picture on my comp comparing stock CA o2 pipe and an aftermarket CA o2 pipe.... after eyeing it for a few, I think I have a CA down pipe.
sjbsuperman1425
CA18DET
too me..the aftermarket O2 housing in the pic kinda looks like a SR20 one, but it might just be the angles. but that downpipe definately looks like a CA one to me.
trevr
The angle is throwing it off, both o2 pipes are CA's.I'm not using any of the o2 pipes in the above picture, nor do I have them to try on the pipe.
I'm this SR outlet pipe
Thanks for your help Zack.. I'm with you on it being a CA pipe
sjbsuperman1425
CA18DET
yea no problem.
do you have the divided O2 Housing installed in the car? i had one and it rubbed on the steering column, but thats when i was using the stock manifold..
trevr
Installed with plenty of room
sjbsuperman1425
CA18DET
looks good. i like the stainless steel lines, im very jealous haha
