blackmagic »
https://forums.nicoclub.com/blackmagic-u56837.html
Wed Dec 09, 2009 3:47 pm
It depends on how worn out your transmissionn mount is. thats why everyone has a different answer. There is just no physical way you can move a transmission back 2 inches if even 1 inch even if you bolt up the worn out engine mount up to the auto crossmember it barely works. I would never recomend running a car hard like this. chances are your mount will rip and transmission will just be bouncing around probably cause driveshaft damage, exhaust damage, and transmission damage. then your out hundreds of dollars when it could have been avoided with just 30.00-50.00
