into the engine.Driving Instructor wrote:Just wondering............where did he put the 3.9 litres of engine oil if it never was emptied?????
.....yeeeeeeaaaah. Ummmm, how exactly do you mistake an engine oil plug for a transmission drain plug? Does your friend just work at Nissan or does he work on them? Was this done at an official change interval at a dealer or done with your buddy in a garage? I ask because it will affect warranty repair if your transmission is shot now or later down the road .bladfin wrote:ok, so one of my friends who works at nissan was helping me out changing oil. instead, he pulled out transmission oil and did never realize. i was pulling my car out of the lot and hit the gas pedal and the car wont move and making weird sound. about 30~40 feet just strolling the car, he found out what he did wrong. straight up, my question is, would my CVT be damaged because of that? he said it would be no problem bec i didnt really drive off but im scared. (i did hit the gas at park or neutral mode just to hear what the noise was)somebody help me please!
I don't think the Versa's CVT works that way. I'm not sure the fluid moves anything. The Versa's CVT is pulley based if I'm not mistaken.Driving Instructor wrote:WOW! CVT......... not sure man. Prob not much but being a CVT..this all new. I know if you had a reg transmission, not a big deal as it needs the fluid to get things moving.
he is one of the mechanics at a nissan dealership and i have no freakin clue how he messed it up. obviously, this wasnt an official service (it was that "homeboy hookup" if you know what i mean). i wouldnt even post a thing up here if this were a nissan service cuz all i need to do is let them fix the issues.Red Devil wrote:
To answer your question, I'm not entirely sure. CVT's are a different animal than normal transmissions. I know it isn't good that you tried to drive off with no transmission oil. I'm sure the metal belts and pulley assemblies have good wear on them now. Which begs another question. When you tried to refill and check the engine oil level and change the filter, how didn't you notice? When you pulled the filter oil should've started to come out. Plus, if the engine wasn't smoking and smelling from the extra oil then it had to be noticed on the dipstick. It would've set off some flags if you would've checked the engine oil.
I don't think you should take your car to your buddy anymore. Sounds like he has no idea what he's doing.
I really doubt they'd cover it. It'd actually probably get the guy fired from his job if he went to the Service department. He helped service a vehicle that wasn't taken directly to the dealer service department. It's worse if the car was still under warranty.alonsorules8 wrote:If he says that the transmission is shot make him pay the $3k to $7K it going to cost to replace the transmission. Or you can try to have it covered by Nissan by going to the service manager at the dealer to see if they can help you out due to the fact the mechanic screwed up you car at their shop.
Apparently instead. He drained the transmission oil and filled the Engine with more oil without draining it. In that case both engine and transmission could be toast.marlin29311 wrote:Ok, just so I get the story straight:
Your buddy was supposed to do an oil change. Instead, he drained the transmission and filled it with engine oil.
Correct?
If so - your transmission is bombed. The Nissan CVT requires a special fluid made by Nissan, called NS-2. It's a proprietary transmission lubricant that is designed to lubricate the metal belt CVT that you have in your car. The CVT requires a different level of lubrication than a standard automatic transmission or manual transmission because of the unique moving parts internal to it that you don't have on a regular transmission (ie, expanding/contracting metal belt). If you page through your manual, you'll see that using anything other than NS-2 in your transmission voids the warranty on your CVT.
In this situation, was this "service" done at the dealership? If so, you might be able to use that to get your transmission replaced (note replaced - Nissan cannot repair the CVT's without having to go back to the factory).
Is this a joke or it's true? I doubt a mechanic can drain the CVT oil and add 4qts of oil into the engine. Was the tech guy high?bladfin wrote:ok, so one of my friends who works at nissan was helping me out changing oil. instead, he pulled out transmission oil and did never realize. i was pulling my car out of the lot and hit the gas pedal and the car wont move and making weird sound. about 30~40 feet just strolling the car, he found out what he did wrong. straight up, my question is, would my CVT be damaged because of that? he said it would be no problem bec i didnt really drive off but im scared. (i did hit the gas at park or neutral mode just to hear what the noise was)somebody help me please!
Engine was done properly, and i actually called the nissan and asked the cervice dept what the proper quarts for CVT is. he said it's between 4~5 and i just have to see and check the deepstick while im fillin in the fluid. so i think im in the safe line.marlin29311 wrote:Umm, from the look of that slip it says he only put in about 4 quarts of NS-2 - your CVT (assuming you do a flush and not a complete drain) needs about 7 - 8 quarts to fill it properly....
Did he fill your CVT with engine oil? Or did he overload your engine with oil and leave your CVT bone dry? Either way, I think you are in for some more problems...
The steel belt plates lock with the aid of the transmission fluid - which creates a crystalline structure that helps the pulley push the belt. Drain the fluid and the belt will not catch on the pulley enough to retain stiffness.CPS wrote:BTW, the belt does not get it's stiffness from the fluid, the fluid creates a cystalline-looking structure on the belt to prevent premature wear. That's why they tell you even a teaspoon of anything else ruins the transmission, because it breaks up that molecular bond of protection in the transmission. The belt is metal and the cones it rides in are metal. Low fluid puts it in failsafe so you can't tear it up. The wrong fluid makes it tear up rapidly.
Good point - first day I got my V I was under the hood looking for 20 mins for it - what a dipstick I am. Seem to remember I couldn't find the hood prop either... And then there was my glovebox thing - my first post.Knightro2 wrote:There is no dipstick for the CVT.
