HELP!!! IS my parts 95 OBD 1 or OBD 2
wanna240now
I just picked up a 95 parts car to feed my 96.
I know some of the 95's were obd 1 and some were obd 2.
The obd 2 port on my 96 is under the steering wheel. I looked on the parts car, and there is not one there. However, under the passenger side airbag, basically right behind the radio, there is a port that looks like the obd 2 port.
Is that where they were on 95's????? How can i tell for sure if i have obd2 or obd 1 in my parts car!!!???
Also, IF i do have obd1 in my parts car, can i still use the transmission on my obd2 car, without throwing any codes????? I'm pretty sure i'll have to use my existing manifold, and just change blocks if it is obd 1.....right???
Thanks a lot for ANY advice/info guys.....
o_alcha3
95' is a strange year b/c it is not OBDII but it is not the S13 setup. I tried to swap a 95 motor in my 89' and i had wiring for a 92...... far from a perfect fit. Check that the wiring will match, i dont believe it sould be a problem if the wires match perfectly from you 96'
