aholloway17 wrote:Today I drained a little fluid and replaced it with Lucas oil, after driving for 1/2 hour it seemed to make little if any change. I did change the filter when I first changed the fluid during which I did notice quite a bit of fine debris on the magnet in the pan. And, again today I could see fine debris in the fluid that was drained though I did not remove the pan to inspect the magnet.
To your question regarding the converter, when changing the fluid should the converter be dropped and filled separately? I though it would refill while filling the transmission?
I seriously doubt this contributed to the issue but...this all happened the very same day I disconnected and removed the radio amplifiers. That wouldn't have any effect on the transmission would it?
Thanks
That debris is likely clutch material or something grinding quite badly.
As for changing the fluid in the converter, I will usually remove it with the transmission and drain the old fluid and refill it before putting it back in place. Why mix new gear oil with old? Especially if there is debris in the older fluid... However, thats assuming that you've removed the transmission in the first place.
At this point you have some choices to make. You could take it to a professional shop for a transmission flush where they'll evacuate all of the old fluid via pressure and replace with fresh. BUT, some people will warn against this (rightfully so) because sometimes its that gooey/gummy/burnt fluid that is holding (dare I say welding?) the clutches and other moving parts together to keep them from letting go completely. As a result, a flush can potentially do more harm than good. (Note that this usually applies to high mileage, under maintained vehicles).
You can probably drive your car as it is until the transmission dies, but in the mean time, be on the look out for good and pick up another used example and have it R&R'd in a weekend, or you could take the possible risk of cutting the lifespan shorter than expected due to the flush. But, as mentioned, the flush is just that- a toss up chance that maybe it will fix it, maybe it won't help at all and you're out the cost of the flush (~$75-100), or maybe it'll be the nail in the coffin.
Either way, a transmission is cheaper than a new car.
Hope I've been helpful.
