N2mesnob »
https://forums.nicoclub.com/n2mesnob-u134729.html
Fri Aug 28, 2009 9:51 am
I was reading through some posts and some mentioned a TBI spacer...Honestly I kinda forgot bout it cuz i'm use to hearing them being used on domestics but it got me wondering if this would work for my setup, is it worth it, pro & cons?If i'm not mistaken it helps NAs more than bossted engines?I'm looking now to see if there are any availiable but so far no joy. i can find ones for newer Paths & Armadas.
Here's something i found on another forum:"Since a 240sx's throttle body will work with the VG30 then the spacer should work as well. Is this correct and is it worth switching?""However, to answer your question, z31parts.com sells either a 54mm spacer for the stock throttlebody, or a 60mm spacer for the Stanza/240SX throttlebody. Personally, I would skip the throttle body spacer altogether though, and instead go for the upper-plenum spacer. This will have a much more benefit on intake air temps, and it will increase the runner lengths, and every little bit can help.""the 240sx throttle body will do absolutely nothing to your vg motor except make it feel as it has better throttle response your bolting a 60mm throttle body to a 50mm plenum.. "
Modified by N2mesnob at 1:05 PM 8/28/2009
