help installing rear differential bushing
skwertle
Ok after trying for hours and alot of cursing, I just can't press in the bushing.
I am trying to press in my rear differential bushing on a 95 240sx. i do not have a drill press, just trying to do it myself in my garage.
getting really pissed of need all the help i can get. any method is appreciated.
NISTECH
If you have a bench mounted vise use that to compress it in.
NISTECH
unless your doing it in the car.
lrciii
Which bushings are stuck on, fronts or rears?Fronts I beat out the inner bushing with a hammer leaving only the metal behind. then I used a hacksaw. Removed the blade, fed it thru the hole & then put the saw back together. Cut thru the metal & voila! it gone. Rears I did simlar, I was able to beat out the center rubber & then used an old screwdriver to beat out the metal parts.
skwertle
no. the problem is i have trouble getting them back in.. to get them out i just burned them out and then hacksaw the rest.
Anyways, i got them in. i just brought everything over to my friends place and he pressed them in with a C-clamp(not exactly a c-clamp but like one, don't know what it is called) and 2 slabs of metal. he used them like a vise to pop them in. it took a couple of trys tho, cuz they would squirt to the side.
Thanks alot guys for all you help.
