BenBenOnDaTrack »
https://forums.nicoclub.com/benbenondatrack-u187472.html
Thu Jul 14, 2011 8:00 pm
I have a jensen vm9311ts that i am trying to install, but when i do all the wiring, i get no power. its not the unit because i have tried another cd player. It says my red wire is to go to the ignition wire, which is red In the q45 right?, and yellow to the battery wire (I sent it to the yellow memory wire ) and the ground wire to the black ground wire in the harnest. now it will not work or power at all, but if i switch the red and yellow wires around, the cd player will make a beep noise and the power button will beep when you press it but that is it. no light, no powering on or anything. I have been at it for 2 days, any help is appreciated. Also i checked the fuse in the cr and cd player and none are blown.
