NISTECH »
https://forums.nicoclub.com/nistech-u7581.html
Mon Dec 01, 2003 6:11 pm
looking at that set up I would say its coming from the gasket under that bolt on peice from the aftermarket shifter. It probably got squeezed out when you put those nut plates on. I think it is leaking when you accelerete hard not nessesarly at the rpm range. Just because of the extreme forward momentum the fluid is sloshing up against that area. its gotta be either that gasket or the boot you tie wrapped on.
