Not 100% sure on the order of the work done. The Infiniti dealer had my car for nearly a week. It was all done at once, and I would think they would have to do the rail flush last? Also not sure if the car was driven hard after the rail flush. I know that is the first thing I did when I got it back!! Lots of WAT's
(per Q45 tech's posts)
My engine looks clean inside, has had regular 2-3 month (usally 4K) Mobil 1 Oil changes, and does not burn any measurable amount of oil during that time span.
I asked the sevice manager about the variance in RPM's and he stated it probably just needs to be driven for a little bit.
QTech, what would doing the test at a higher RPM indicate?
