navysnail »
https://forums.nicoclub.com/navysnail-u13430.html
Tue Apr 11, 2006 4:15 pm
no, the brake booster and the cylinder itself are isolated from one another. if it leaked enough into the booster, i suppose it could fill it to the point were the line connects, but by that point you should have considerable brake problems (like the brakes doing nothing).pop the hose off and see if it is filled with fluid, that will tell you your answer right away.
