RideFX »
https://forums.nicoclub.com/ridefx-u6800.html
Tue Dec 09, 2003 11:43 am
This morning I went to drive my car and when I went to shift into first it was REALY notchy. Shifting into second and thrid was also kinda notchy. The first thing I noticed right away was that my clutch had A LOT of play, like depressing the clutch pedal didnt have any effect until the last little bit. I had to drive my car about 80 kms to work, and throughout the drive it got worse and worse, it felt like there was clutch fluid leaking, and my clutch pedal had more and more play(shifting got more notchy as well). The last time I shifted into first I could barly get it in gear. Anyways when I got to work I cheaked the clutch master Cylinder and it was prety much empty, there was just a tiny bit of fluid way at the bottom, not even in the holding part, like was down at the metal thing. I followed the line from the cylinder untill where it leaves the engine bay and I couldent find any leaks....Does anyone know what this is? Is this my clutch or is it some kind of a leak or slave cylinder? I dont really have any cash to get this fixed, it this something that is easy to fix my self? Im kinda stuck at work right now cuz I dont want to drive my car, any info would be hugly appreciated!
Thanks
George
