HELP!!! Im a noobie!
A home for 1983–1989 300ZX owners!
toneZ
Car: 1985 300zx
Im a noobie my name is Greg. I have an 85 300zx non turbo and im havin trouble with getting her to run cherry.. When she does she runs great and supper fast.. She is bogging only on acceleration and its really when i try to open her up. Sometimes she will just bog for a bit and than kick in but also sometimes just gets stuk in bog mode in all gears tell i drop her in neutral for a bit.. Iv replased the plugs and wires NGK.. fuel pump and filter checked the vac hoses... cant figuer it out can someone please help me ...
Jaykit
Car: 1990 JDM Fairlady Z32, Twin Turbo, 2+2, Silver
You might want to check out the Classic Z Forum. Its where they talk about all Z's older than the '90 model. Good luck with fix.
AZ-ZBum
Car: 05 Nissan Murano
84 Nissan 300ZX Z31 AE
88 Nissan 300ZX Z31 Vert
toneZ wrote: Im a noobie my name is Greg. I have an 85 300zx non turbo and im havin trouble with getting her to run cherry.. When she does she runs great and supper fast.. She is bogging only on acceleration and its really when i try to open her up. Sometimes she will just bog for a bit and than kick in but also sometimes just gets stuk in bog mode in all gears tell i drop her in neutral for a bit.. Iv replased the plugs and wires NGK.. fuel pump and filter checked the vac hoses... cant figuer it out can someone please help me ...
Do a tune up.
plugswirescaprotorfuel filteretc.
then check timing.
Prophetmp
Car: S30
start out small, the MAF or could be just a hose leak, spray them with soapy water or WD-40, if there's a leak you should notice a change in the rpms It's just a guess..wires,plugs,and rotor cap are good places to look too.
Return to “300ZX (Z31) Forum”
