HELP ignition timing
Mr.toofotay
i recently bought a new timing chain kit and installed it but when im trying to crank the motor to set piston #1 at T.D.C the crank seems like its stuck and im about to break it? is this normal? thanks.....
180fan
Car: 89 fastback
it's probably hitting the valve. did you set both the crank and cams properly before pulling the chain off?
Mr.toofotay
hey yeah i set the cams and crank before putting the chain on. i can rotate the crank once 180 degrees but then after that its feels stuck?
