Help Ignition Problem
hotcakes0007
Car: 2002 Lexus Is300
Yea so i just started driving my sr20 in my 93 s13 and the car drives fine and starts up with no problems the only thing is that when i go to shut the car off the radio and gauge cluster turns but car stays on and all the lights on the dash stay on but the spedo.....Does anyone know what this could be?
fast_s13
sounds like you have constant 12volts going to the 12 volt switched wire on the ecu
Emperor_Tha
double check to see is the gauge is tap into a constant 12v power
hotcakes0007
whats the color on the ecu for the sr to see if maybe thats what it might be, but like i said shouldnt the car at least turn off instead of me having to take out the fuel fuse to turn it off?
hotcakes0007
hmm something else wierd since this has happen i have been having To take off my battery at night well when i plug it back on in the mornings the ignition doesnt come on untill i turn the key on i dont know if that helps.....
