I'm pretty sure there isn't anything else wrong, what else could be wrong? Now the mechanic said they made two different ecu's for the 5 speed 97' 240 and he can't tell them apart so is there anyway I could tell. Because I don't want to drop 50 bucks and have it not fix the problem.Asmar wrote:I just did a 5-speed swap on my '98 S14 like a week ago and had the same problem. I picked up an 5-speed ECU for $50 and installed it and the "Service Engine Soon" light went away. It's really not that big of a deal though, the mechanic is charging you too much for an ECU, just look for one locally. It should cost you around $50-$150 for one. Did you check if everything else was done right on the swap?
Auto And 5-Speed...No?Dire91 wrote: Now I need to find 1 of the 2 ecu's
Bellhousing sensor?sebazztard wrote:find a s14a 5 speed ecu, swap, if the light is still on remove the bulb. its only throwing a code because of the bellhousing sensor. your prob rocking an s13 transmission too.
