DevZX »
https://forums.nicoclub.com/devzx-u202565.html
Sun Jun 01, 2014 3:05 pm
hey guys so my car has been running horribly ever since i had work done to it almost like a missfire but i removed each coilpack connecter and car idled worse for esach of them. it also has no power above 3k rpms. i had z1 ecu upgrade, 120k kit, jecs 550cc injectors with adapter kit, dual air intake, aluminum pullys, full exhaust, egr delete, aiv delete, ac delete, plenum waterline delete.. and i think that is it.. well the problem is the guy that was working on my car im pretty sure he didnt know what he was doing.. he ended up removing the plenum multiple times to replace injector orings and im pretty sure he just hit them to get them out...... now my cars been having white smoke coming from driversside plenum area and exhaust so i was thinking maybe an oring. so i removed the plenum turned the fuel rail upsidedown and the injector i thought it was fell right out.. so i replaced the orings for that injector put everything back together and car runs the same.. but after awhile ALOT of smoke started coming out from both sides of exhaust and engine bay and i see liquid driping onto pass side turbo... the smoke is white and my neighbor said it smells like a mixture between oil and fuel... help me please.. sorry for my essay i failed engish..
