I’m in need of some assistance on my 96 Nissan 240(KA). I reinstalled my clutch fan/cooling fan and shroud in place of the nonfunctioning electric fans I had from before. However, all those years ago I had cut the harness end of the plug that leads to the cooling fan and have since discarded it. What I need to know is the proper wiring order since now I’m reattaching them one-by-one using crimp connectors (see pic). I’ve included a picture below showing the wires in question. These wires are located to the left of the radiator (my battery is relocated). I know that the two black wires on the harness end are grounds. I also know that the W/R and the BR/W wires are for the high and low fan speed, though I don’t know which is which. The wires to the right go to the cooling fan itself, and I have no idea which wires correctly connect to the harness. If someone could simply look at there’s and help me identify the proper connection, it would be most appreciated, since the service manual I have only identifies the harness wire colors.
