Help Identifying Wires (Simple)
scotty-2-forty
Car: 1996 Nissan 240SX SE KA24DET
Okay guys/gals, I’m in need of some assistance on my 96 240(KA). I reinstalled my clutch fan/cooling fan and shroud in place of the nonfunctioning electric fans I had from before. However, all those years ago I had cut the harness end of the plug that leads to the cooling fan and have since discarded it. What I need to know is the proper wiring order since now I’m reattaching them one-by-one using crimp connectors (see pic). I’ve included a picture below showing the wires in question. These wires are located to the left of the radiator (my battery is relocated). I know that the two black wires on the harness end are grounds. I also know that the W/R and the BR/W wires are for the high and low fan speed, though I don’t know which is which. The wires to the right go to the cooling fan itself, and I have no idea which wires correctly connect to the harness. If someone could simply look at there’s and help me identify the proper connection, it would be most appreciated, since the service manual I have only identifies the harness wire colors.
sx moneypit
Car: 2010 Nissan 370Z
1986 Toyota MR2
If you can wait till lunch time i will go check mine out.
scotty-2-forty
sx moneypit wrote:If you can wait till lunch time i will go check mine out.
I got all day, thanks!
sx moneypit
1986 Toyota MR2
The white and brown goes to the blue wire ,the white and red goes to the green wire.
scotty-2-forty
sx moneypit wrote:The white and brown goes to the blue wire ,the white and red goes to the green wire.
Thanks a million dude! Is the green a ground then?
sx moneypit
1986 Toyota MR2
The other two wires are grounds.
scotty-2-forty
sx moneypit wrote:The other two wires are grounds.
Thanks, much appreciated!
scotty-2-forty
Bah, I meant to ask if the "yellow" was a ground, not green. In any case I take it, yes?
sx moneypit
1986 Toyota MR2
Yes sir .
scotty-2-forty
sx moneypit wrote:Yes sir .
You are the man.
sx moneypit
1986 Toyota MR2
Thank you .Glad i could help you out!
