Help Identify wires...
yellow2000SR
Car: 92 Nissan 240sx 98 Ford Escort ZX2
Some info: 92 Hatch, KA24de, bought it a few months ago knowing the motor was blown.
Issue: Shaving engine bay, found 2 small wiring harnesses cut. And I believe the silver cylinder shaped piece is a position sensor of some sort (cams or crank?).
Ill go out and check the coloring of the wires now.
Below is a pic of the cut wires
Modified by yellow2000SR at 3:13 PM 8/25/2007
yellow2000SR
Found this crimped together under / next to the fuse box...
malten02
Car: 1991 240sx
i would love to help you, unfortunately i have a few unidentified myself!!!
TRUSE-R
The cut wires you have pictured are sensors for an automatic transmission. Your car could have been an auto which they converted to standard, and the wires and sensors are no longer needed (if your car is standard).
