That's good to hear...lrb_2000 wrote:eh.. looks like it would be good to around 300whp.. ish.. full boost around 2600 rpms. yay.
hell yes, just go for it. Besides, 250whp on a t3/t4 is cake.S13FX wrote:At least if you stay the T3 route you will have a lot of room for upgrade later on ..
Yeah. Ok. I think Im just going to go with the JGS kit, minus the turbo but WITH the wastegate.spooled240 wrote:i have a .63 a/r and i see the full 9psi at 3000rpm's so .68 wouldn't much slower
and remember even at the same boost, a bigger turbo will pass more air due to the volume and the car will be faster. So at 250rwhp, you probably only need to run about 10 psi-ish -i'm guessing
Thanks man, I will.spooled240 wrote:good choice, I would've went with them but I started with the ebay mani so i couldn't use their downpipe etc..good luck man keep us updated when you get it rolling..
I doubt I'll make 250whp starting out, since I'll be using a smic setup at first. Thanks man.Zippy69 wrote:Isn't almost impossible to NOT to make 250hp with a t3/t4 set up? I mean as long as you are tuned properly, it should be an easy goal. Good luck and post some videos, even if they aren't of your car and contain only scantily clad women, that would be fine.
yeah how about that video?..250hp is not hard to do on a t3/t4, even with a smic IMOZippy69 wrote:Isn't almost impossible to NOT to make 250hp with a t3/t4 set up? I mean as long as you are tuned properly, it should be an easy goal. Good luck and post some videos, even if they aren't of your car and contain only scantily clad women, that would be fine.
