The manuals can be found at
http://www.importworkshop.com/files/man ... manual.pdf
Im swapping a rb20det into a s14 chasis. I need assistance identifying a couple plugs/wires/parts. Im attempting to clean up another inidivuals attempt at the wiring and removing all the uneeded wires (not running a/c or consult).
The first item i have a question about is pin 104 on the ecu connector. Its a green w/ white stripe wire that goes to the white 12 pin conector on the rb harness. In that 12 wire connector there are 5 wires out of the 12 pins that are actually used. Light blue, orange, white, black, green/white. In the FSM it list the wire as
Fuel Pump Volt Control Output. The fsm shows this wire (pin 104) going to the Fuel Pump Control Modulator (pin 1) (FPCM) Is this wire needed?
Secondly, comming from the same 12 pin connector on the RB harness there is a white wire and a black wire that goes to what looks like a resistor pack of some sort. What is this box and is it needed?
Finally, comming from the 12 pin connector on the RB harness there is an orange wire and a light blue wire. These two wires terminate at a 6 pin plug on the RB harness. What are these for and can they be eliminated?
I guess with all that being said....what i'm really asking is...... is the silver resistor box looking item, 12 pin RB connector, 6 pin RB connector required for the motor to run?
Below are pictures:
Wire comming from pin 104 on ecu connector.
12 pin connector on rb20det harness.
Silver resistor pack? white & black wires.
6 pin connector on rb20det harness that orange & white wires from the 12 pin connector terminate at.
Any help and/or input would be appreciated...... CarlH this means you!
Sry for the quallity of the pics...cell phone pics
