Help identify these items
TwinTurboFred
Car: 96 S14 , 89 S13
Please identify the cylinder highlited in yellow, as well as the 4 inlets on the firewall. The car is an 89. Thanks!
180fan
Car: 89 fastback
black box - windshield wiper ampviolet - your fuse box on the left and relay boxes on the rightyellow - looks like a fuel filter with the clamp that should be on your shock towers still on itgreen and purple - your lines to the ACred and blue - your heater core
dsc4130
and it looks like your motor mounts are non exsitant
TravisD
Red-coolant into the heater coreBlue-coolant out of the heater core (goes to a tube that runs through the bottom of your intake mani.) the hose that goes there is apparently not available from Nissan anymore. I had two dealerships in my area tell me that.edit: And yeah, that's definitely the fuel filter hanging there in the yellow box.
TwinTurboFred
It doesnt look like a fuel filter, it was mounted to the pass strut tower, and looks like a power steering resevoir or something. It has a cap that screws off, and I have never seen a fuel filter do that.
kansaschity
Car: 92 240sx
the po
TwinTurboFred wrote:It doesnt look like a fuel filter, it was mounted to the pass strut tower, and looks like a power steering resevoir or something. It has a cap that screws off, and I have never seen a fuel filter do that.
the power steering resevoir would be on the driver side. unless its different from the de
benemorius
Car: s13, s13, eg, e36
Though I can't see it very well, yellow would have to be power steering reservoir. It's on the passenger side on the 89-90 and driver side on 91+.
TravisD
OIC. Thanks for the correction.
