Help identify these gaskets
hayai_240
Car: 1989 240sx Coupe
I got some gaskets as part of a trade and need help identifying what gaskets they are.
1- Spark plug hole gaskets? Don't look thick enough2- Fuel injector tip gaskets?3- ?4- Looks to be the front main seal gasket. But the buyer said he used it. The part# on the gasket says 13510-53J11. All the pictures of this part# i've found say 13510-53J10.5- ?6- ?
karmakaze
Car: 98 240sx SE
1 is the upper injector oring2 is the lower injector oring3 is the oring that goes on the CAS6 are the crush washers for the coolant and oil banjo bolts on the turbo lines
i don't remember what 5 is. and your correct on 4
240trackjunkie
Car: 1990 Nissan 240sx
#5 is the oil fill cap gasket.
exode
Car: 90' 240 w/ 400hp SR20DET
trackjunkie could be right, check that. Second guess would be for a HKS style BOV mount.
spider_slayer
Car: S14 240SX
S13 240SX
for #5 there is also a that looks similar that goes on the front cover by the water pump assembly.
efrain240sx
Car: 1992 nissan 240sx HB
spider_slayer wrote:for #5 there is also a that looks similar that goes on the front cover by the water pump assembly.
Yeah thats true but then it should be the size of #2
