Help identify my 2way lsd.
nodr1ft
I bought the lsd from a importer, the guy said the diff is a s14 2way nismo. I took it home, took it apart, now im trying to figure out what brand it actually is. A kaaz, tomei (i know they are the same), nismo, or whatever.
final drive says 47:12 .. im trying to figure out what diff it is without disassembling it, and i am in the middle of a sr20 swap waiting for the parts so i cant just installing and go beating on it
these are the pics i took a couple minutes ago..
kaaz lsd.. if you can see, my lsd has the same circles with the flat part on the side near the flange
some random nismo 2way pics i found online
any help would be great thanks
Razi
Car: Moo
Looks like a KAAZ to me.
nodr1ft
Razi wrote:Looks like a KAAZ to me.
the more i compare the pictures to the kaaz.. it looks like a kaaz..
is there anyway to tell if its either a 1.5 or 2way?
Razi
Car: Moo
Nope, not that I know of..
kozanatos
Did you get it at a good price at least? So if it isn't real your happy?
ILoveMyRHS13
Car: 1990 Nissan 240sx (Hatch)
It came with a 3.9R&P. Doesn't really matter which one it is because most LSDs are made by KAAZ anyway.
nodr1ft
kozanatos wrote:Did you get it at a good price at least? So if it isn't real your happy?
$450 .. , but i have to do the s14 bushing mod or get spl solid diff bushings for the s13..
Modified by nodr1ft at 4:19 PM 2/24/2010
ILoveMyRHS13
Just swap diff covers?
nodr1ft
that too but s14 diff have a rubber bushing when s13 diffs just literally bolt straight to the frame. metal to metal
i also might need a s13 abs driveshaft since it is .75 shorter.. the s14 diff is a little bit longer
ZX88
Car: s13
not a tomei t-rax
jessetang
Car: 1995 240sx
47/12=3.91666666666
That's the gear ratio for your final drive.
nodr1ft
just ordered SPL z32/s14/j30 solid diff bushings for s13
