[img
][/img][img
][/img]
][/img]
][/img]The More You Know ~*other people wrote:the stock ones from Nissan are filled with goo, and eventually they will fail.
It's silicon filled, if I remember correctly.Razi wrote:I've been told that the OEM bushing has some sort of goo inside it, but I've never taken one apart so I can't be 100% sure.
You can remove it and replace it for cheap with a polyurethane one from Energy Suspension.
Z1 also has a solid replacement for the bushing too.
http://www.z1motorsports.com/product_in ... ts_id=5579
Adjustable tension rod arms are nicer, but they are a bit pricier.
It's a simple deal to pull them out and replace them. Make sure to grab a mallet to convince the bolts through the bushings to come out. I usually grease those bolts when I reinstall them. Makes life a little easier.RickBlaine wrote:We all have to learn. I am just thankful that other's are willing to offer help.
After reading through a few threads- it seems many of the suspension components are "plug and play" with just socket wrenches and a breaker bar needed. Is that correct?
If I replace just the tension rods, do I need to get an alignment right after?
It's hard to find them with rubber already pressed in. Megan makes a cheaper alternative to Nismo bushing, just do a google search to find some online stores that sell them. But if you don't have the capability to press them in yourself, find a shop that can and get a price quote on how much they'll charge. Some shops overcharge because they can. If you're trying to stay with rubber up front due to cost, the added shop cost can easily toss the price over a set of cheap tension rods with spherical bearings (pillow balls) on them. Case in point, I took my GT-R rear knuckles to have the bushings pressed out, and the bill was $120 for an hour and a half. I cased another shop to press in my spherical bearings, and they wanted just as much. I just found a cheap 12 ton hand press on craigslist for half the price and did it myself. Granted, my uprights are way more complex to set up than the TC rods, but it's best to get that kind of stuff in a row before you get the bill. My jaw nearly hit the floor when I saw the bill for having the bushings pressed out.RickBlaine wrote:Hijacker: Thank you...you have convinced me to replace the bushing material with something OTHER than polyurethane. Most aftermarket stuff I saw was either poly or solid. I'd probably want to get a kit of some sort and spend a day swapping all the suspension pieces out. I am not racing it- I decided to keep it as stock as I can.
Do you know of any company that sells re-manufactured pieces with the rubber bushings already in place?
