Help!! I35 only blowing hot air!!!!
RedRubyPearl
Car: 2003 I35
Hi im new to Nicco welcome me please!
Im having a issue with my A.C. it only blows hot air could it be a bad compressor?
loystock
Car: 10 Honda Pilot
97 Infiniti Q45
03 Infiniti Q45
97 Infiniti I30
06 Infiniti M35 Sports
04 G35 & 99 I30-RIP
With the AC on, you have to check if the AC compressor clutch is engaging or not. If it's not engaging, you may have an electrical problem (fuse/relay/wiring) or the compressor is disabled/inoperative (due to high/low pressure switches on the air drier, overheat thermostat in the compressor itself, defective compressor clutch or the compressor itself has failed). If the compressor is engaging/running, then you have to check the Low Pressure and High Pressure sides to isolate the problem. At 86F, the low pressure should be 31-37 psi while high pressure is at 149-185. Pressure will be lower at lower ambient temp.
There is also a built-in diagnostic available for your air-conditioning system.
Fezzik
Car: 2010 G37 Vert w/ stage 1 GTM supercharger
RedRubyPearl wrote:Hi im new to Nicco welcome me please!
Could you be out of refrigerant? My 02 max finally ran out this summer.
NutriaforBreakfast
Car: Nissan Maxima 1995 VQDE engine
Use this website to learn about ac
Tech Pages (tab up at top)
Nissan Technical
Nissan General
Nissan and Infiniti Air conditioning systems
RedRubyPearl
Car: 2003 I35
checked the refrigerant. STILL having the same issue
im strongly leaning to a new compressor
loystock
Car: 10 Honda Pilot
97 Infiniti Q45
03 Infiniti Q45
97 Infiniti I30
04 G35 & 99 I30-RIP
Please clarify as to how did you check the refrigerant. What's the low and high side pressure? Such readings are helpful in fault isolation. Some have replaced the compressor only to find out that the problem was with the expansion valve. And replacing the compressor requires specialized equipment to evacuate the system, store the refrigerant, recharge the system and check for leak.
NutriaforBreakfast
How to check refrigerant and info on high and low pressure side of compressor
On this website;
Go to top of page at Tech Pages
Nissan Technical
Nissan and Infiniti Air Conditioning Systems
http://www.nicoclub.com/FSM/maxima/1996/HA.pdf
Page HA10 shows the AC system
Page HA31 bottom table details high and low pressures of compressor
Also Mastercool makes a lot of AC service equipment
Autozone has tools to evacuate the refrigerant, manifold guages, and refrigerant
NutriaforBreakfast
I helped you with a 96 maxima rather than an I35. Use the URL to look for your car
teddyp81
Car: infiniti i35
I know this is a old post but I am having the same problem with my car. How do I access the "built in" diagnostic for my ac for my car?
