help! i think i popped my motor.
Nissan 350z / Nissan 370z general community discussion forum
Mazx6
Car: 2003 Nissan 350Z Twin Turbo
So i'm driving up my girl friend's street in 2ed gear at about 5-6psi of boost. while i'm driving i hear a loud knocking sound coming from the motor. I'm assuming its a knocking rod. I did a compression test shortly after and here are my results:
Driver side from front to back:
150psi160psi146psi
Passenger side front to back:
152psi120psi155psi
I'm taking it to Nissan in the morning to see if i can get an exact diagnosies on it. I know some of you guys have had the same experiance i want to know what happen in your all cases. thanks.
I have the greddy TT kit along with an e-manage and a J&S safegaurd.
C-Kwik
The compression test results don't look encouraging. Probably looking at at lease bad rings. I'd guess the piston has some damage as well.
nsrZ32
Car: 90 Nissan 300ZX TT
78 Datsun 280Z
71 Datsun 521 Pickup
98 Nissan Sentra 2.0 SE
02 Nissan Altima 3.5 SE
01 Ford Focus S2
Hey! I have pictures of your car from HIN cleveland I had my Z there too.
Best of luck on your motor btw.
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
I am concerned about the 120psi reading there. You should really do a leakdown test. Compression testing only tells you that there is an issue. Doesn't tell you anything about whether it is with your valves or your rings.
If it's time to rebuild, get some forged internals in there and upgrade your turbos/fuel
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
sounds bad, time for a sleeved darton block!
I have been considering a forcefed 350z lately, and still want one but it seems the Z33 blocks are not up to the abuse of other Z generatiosn, the good news is that there is already an improved aftermarket block on the market and at $1300 it honestly not a bad deal, especially when it comes bored up to 100mm (total displacement 3.8L) even got a stroker crank to tkae it up to 4.2! I will be amoung your ranks but with the investment that it's gonna be it'll have to wait a year or 2
Return to “350z / 370z Discussion”
