Help!! I only have high beams!?? Where is the fuse for parking lights/headlight?
lele
Car: infiniti 1997 J30t
For some reason when i turn on my headlights the high beams come on automatically? And my parking lights are not working? I don't see on the fuse box where these fuses are? Can anyone help me?? Thanks
gotspeed
Car: 96 nissan pathfinder 97 infiniti J30
Sounds like you have a headlight relay problem, go to http://fuzzycats.com/j30_diy.htm and click on the Headlight link. I got a used relay off of an wrecked J30 and I haven't had any problems, but of course you run into the problem of buying one that is almost ready to got out, so buy at your own discretion.
yodawill2000
Car: 94 Infiniti J30
I got a new one from the local dealership for about 25 bucksBut theres been a price increase since..Should be in the 30's now.
lele
Thanks guys...I will check this out!!!
fogged306
Car: 1997 j30
Not too sure on this one, but you might want to check out your actual high beam switch in the stalk too. I've had problems with mine. Sometimes when I turn on a blinker my high beams flicker, so I'm assuming its going bad.
gotspeed
actually, The relay can cause the same problems you described.
93jdirty'
Car: 1993 Infiniti J30
the fuse is in the driver side kick panel this happened to me also. all it was is a fuse. i even replaced the relay before checking the fuse which didnt do anything. Replace the fuse!!! even if it looks ok it still can be blown!!!fyi
yodawill2000
Blown fuse causing the High beams to come on ??Bizzare.
gotspeed
93jdirty’ wrote:the fuse is in the driver side kick panel this happened to me also. all it was is a fuse. i even replaced the relay before checking the fuse which didnt do anything. Replace the fuse!!! even if it looks ok it still can be blown!!!fyi
I can never say never but the chances that a bad fuse would allow only the high beams to operate is hard to believe.
93jdirty'
When the parking light fuse shorted out on my j i turned on the headlights and nothing but the high beam would turn on, It is probably a safety feature to prevent loss of all light in case of a short while driving. after i replaced the fuse all was back to normal.
yodawill2000
Good Info !!
