Sil240 »
https://forums.nicoclub.com/sil240-u6842.html
Sat Oct 06, 2007 7:47 am
I would take that motor out of the car and take it to a machine shop if I were you.
Do you have the measuring tools and know how to use them?You can get the block honed and put in oversize rings, but I'm not a fan of that.Plus it depends on how much wall damage you have.
Also how do you know its rings???Have you done a leak down test on it?Test it first before you do anything.It could be not seating valves, bad valve guides, HG any one of those could give you oil and bad compression.
Plus also you need to check the ring lands, usually those get damaged.
Good luck bro
P.S. JE has RB20 pistons.I bought the first set and got raped because they have never made them before. Should be cheap-er now.
