toki »
https://forums.nicoclub.com/toki-u4152.html
Sun Mar 27, 2005 3:52 pm
the t3 will make little power, and the t4 is too big for any fun on the street. Go for a .63 a/r T3 turbine housing (hot side) with a T04E wheel, the 50trim is the most common for street apps, if you are looking for 350-400 hp (300-350whp) then it will be perfect, if you want more, I would personally rocommend a 60-1 compressor on the same turbine housing.
