help..i need ca18det oem parts
Komatsu X
Car: Silvia
hey i checked my compression today and it was low.. so i wanted to know where can i get oem pistion rings?..i heard they where the same as the ca18et is this true??
o yea i need oem head studs and headgasket are they the same as the ca18et engine? if not dose anyone know any good online stores that i can order them from right now? i didnt want to get them from ebay because i couldnt find oem studs and headgasket only aftermaket.
c-rad
Car: 1991 Nissan 240SX w/CA18DET
they are all the same as the CA18DE engine.
rico05
Car: 1992 RMS13 w/ CA18DET
I am running a Felpro headgasket for a CA18DE. Retail is $76 at O'reilly's, but my buddy works there, and i got it for HELLA cheap (Like <$20) So far, it is taking 12psi in stride. For studs, I can't remember the part number: but ARP makes a set for the CA now. Or you can order the MAIN stud kit for an SR20DET and that will work as well. I bet you can't find factory studs outside of the dealership anyway.
