help! i have some problems with my new rims
jinusosilly
Car: Drifting
my friend has a accord and he had a set of racing hart c2s that he wasn't using, so just let me have them.
i had put them on and they look a lot nicer then stock...went for a drive and both rear wheels wables! so i pulled over and checked it out...the nuts got loose some how, tighten both wheels and noticed that one side of the rim there is a gap between the rotor and the rim. so im thinking the thing in the center...i dont know what it is the thing in the middle of the rotor,
so do i get a 5mm spacer? or is it the studs? when i look at the studs, they look perfectly fine and the rims aren't bent.
quiksilvia
Car: 95 s14 se
its not hitting the brakes is it? wrong offset?
jinusosilly
Car: Drifting
its not hitting anything, the offset might be a little off but the rim isn't hitting anything
sleepy001
Car: my family car club and my girl
whts the rin madeout of and thelugs made out of .steel lugs for aluminm and vic versa steel rim aluminm lugs
Bio_Hazard
Car: a crushed 1990 240sx
i'd say a spacer. when i put mine on they told me i could use a 1mm spacer dut didn't need it. did the shop (I assumeyou went to a shop) tell you that you might need a spacer? if so i'd go get one.
vuse1
the hubs are different sizes, accord rims wont' fit 240s. i've tried and i know from expierence, i went through the same thing as you.
Toahk
Car: 97 ....
accord is 4 x 100 and 240 is 4 x 114.3 right?
vuse1
they are both 4 x 114.3
p00t
you probably need some hubcentric spacers. it sounds like the wheel isnt leaving enough clearence for the center portion of the wheel. hubcentric spacer might fix your problem but will push the wheel out a bit farther. If i was a mod i would move this to wheels and tires where you would definately get an answer from exar-kun or grant.
