Help. I have problem with 3rd cylinder. Any suggestions?
martnikolov
Car: Infiniti g20 1993
Hi I own Inifniti G20 for about 5 years. I servicing the car in Nissan. Never have any major problems. Drives good.But let my girl-friend drive for 1 day and then the next day has a problem.The 3rd cylinder does not work. I change the spark plug and the wire and the is a spark but still the cylinder does not work.Please, help me. What could be the problem?Injector?
Thank you.Martin
bone_stock_240
Car: 1995 Infiniti Q45
Yeah, if you are getting spark, then the next thing to look at would be the injector. Oh, and don't forget to lay a guilt trip on your girlfriend for breaking your car so you can make her your sex slave for a little while.
Twilight sentra tuner
Car: 00' Sentra Gxe
could be a number of things.
hope it is the injector.
the compression rings on ur piston have gone bad. if ur exhaust is a blue color then ur oil control ring has gone bad too. these must be replaced if its your piston. this is worse than the injector but not worse than whats next.
cracked cylinder sleeve. most people swap out the motor or trade in the car. this is an expensive repair. this is a worst case scenario.
AWDB12wagon
Car: 1989 Nissan Sentra 4WD
Definatly an injector, they are common to go out on these motors.
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
Exactly. Either injector or ECU. I have had both happen to me.
