Help!! I Have All The Info About My Enigne!! Please Help!!
ESPER
Hello!! well i just found out that as i was degreasing my engine, water got into the 4th spark plug hole!!! well i dried it out (along with the other 3) and althought the engine stopped jerking during idle, (it idles fine now) it jerk during acceleration!! and theres a vapor constantly shiooting up from the clutch rod!! what should i do?? any idea on damages/repairs costs at a mechanic?? thanks!!
drjohn
Jerking on accel check for water in the dist. cap. Dry the cap and let the dist dry out for awhile. If you have compressed air lightly blow the cap and dist. out. Hold onto the center carbon tip in the cap though so you don't blow it out.
ESPER
well i got all the moisture out from the cap and plugs, etc. one last thing, it seems a mixture of oil/water has leaked onto my clutch shifter, and tats whats vaporizing when my car gets hot, i have wiped it all off, but waht caused that?? is tehre anything else i should check for to prevent further leaking?? thanks for your help man!!
