Postby
downs »
https://forums.nicoclub.com/downs-u32044.htmlSat Aug 27, 2005 2:06 pm
I add anti-freeze and it drains into the oil. People have told me cracked block, cracked head or just a head gasket. Please tell me what you think it is.
Postby
SOHCSE »
https://forums.nicoclub.com/sohcse-u29947.htmlSun Aug 28, 2005 3:35 am
downs wrote:I add anti-freeze and it drains into the oil. People have told me cracked block, cracked head or just a head gasket. Please tell me what you think it is.
Postby
TheOne »
https://forums.nicoclub.com/theone-u18820.htmlSun Aug 28, 2005 5:52 am
most likely your headgasket though, a cracked block is rare unless a con-rod went through it, a cracked head could happen after the car has overheated, and a headgasket could happen cause of many miles, and cause of overheating.
Postby
1991S13 »
https://forums.nicoclub.com/1991s13-u22320.htmlSun Aug 28, 2005 3:28 pm
The head doesn't necessarily have to be cracked, it can just be warped bad enough to let antifreeze in. I'd put my money on head gasket though. Mine blew in the beginning of the summer and I had coolant in the oil pan. The guy I talked to at Phat KA-T told me the head gaskets on KA's usually blow in the back so its hard to see if anything is leaking.
Postby
Kenrik »
https://forums.nicoclub.com/kenrik-u28233.htmlSun Aug 28, 2005 3:45 pm
also if your timing chain is loose it can eat it's way into the coolant system and drop coolant into the oil pan...Don't drive your car till it's fixed unless you wana blow your engine.
