fun240 »
https://forums.nicoclub.com/fun240-u58771.html
Thu May 21, 2009 12:46 pm
The seal around the hatch where the hatch closes to the frame probably needs to be replaced.
It is really easy to do it, and you can find a good seal from a partout - Nissan was really high i think
The seals also around the taillights...
The best thing to do, is remove trunk carpeting, backseats, and panels
Then drive through an automatic carwash. The pressure from the sprayer will show you exactly where you're leaking!
Also the gap on my hatch was a lot bigger then yours and it never leaked. This is a rundown spot anyways.
If there is a lake in your spare tie holder then you are leaking from the tails most likely. It'll rust up fast if you dont repair it.
Butyl from Home Depot
