HELP!! i flubbed up bad i think
Discussion forum for body kits, repair, modifications, interior styling, Audio / Video and internal/external lighting.
timmy0257
Car: 08 Infiniti G35 Journey 5AT
-R2C Intake
-interior LEDs w/ tag lights
-SBD grounding kit
-TBW engine cover
-Eibach Pro-kit
-JL Audio
Future Mods include GT-Spec strut bar & more.
i need major help. i feel like i am about to have a heartattack.
i was trying to do a fix for my 08 g35 sedan. it is auto without nav. i was attempting to disable the safety feature that prevents video from playing while the car is moving. i got the walkthrough off of here. it had my terminate two wires behind the stereo system. i did this (and yes it was the correct wires) and when i put it all back together, my car will not start. in fact, whenever i try to turn it off completely, its turns right back onto the ACC. i reconnected the wires to how they were and disconnected the battery as i am typing this.
my initial thought was that the batt needed to be disconnected to reset itself. since our cars do not have a key position, it was stuck in the ACC.
what do you think?
please agree with me.... :/
timmy0257
-R2C Intake
-SBD grounding kit
-TBW engine cover
-Eibach Pro-kit
-JL Audio
well i got the car to start at least... then it wouldnt turn off. i actually have to hold the ignition button down for about 4 seconds and it will turn off.. is this normal? i have going to put it all back together and go for a drive to check everything.
please help, friends...
timmy0257
-R2C Intake
-SBD grounding kit
-TBW engine cover
-Eibach Pro-kit
-JL Audio
put everything back to together as it originally was.
car will start. but it is very odd getting it to turn off.
VDC ABS and other lights are on. fuel gauge does not work.
timmy0257
-R2C Intake
-SBD grounding kit
-TBW engine cover
-Eibach Pro-kit
-JL Audio
btw, this is the walkthrough i was using.
how-to-bypass-video-on-a-2008-g35-t331450.html
timmy0257
-R2C Intake
-SBD grounding kit
-TBW engine cover
-Eibach Pro-kit
-JL Audio
No A/C either. did i blow a fuse?? i was doing all this and never disconnected the battery
the instrument panel unresponsive. its lit up, but no readings. doesnt even tell me what gear i am in. (auto transmission)
timmy0257
-R2C Intake
-SBD grounding kit
-TBW engine cover
-Eibach Pro-kit
-JL Audio
timmy0257 wrote:No A/C either. did i blow a fuse?? i was doing all this and never disconnected the battery
i just checked all my connections and everything is secure. does something need to be reset? negative batt cable was disconnected all night and i do not think i can do the ECU reset because the ignition button is not acting right.
is there another way?
my only suspicion is that a fuse is below or i fouled up a relay somehow.
please friends, i really need some help. i need to fix this before the weekend is over.
timmy0257
-R2C Intake
-SBD grounding kit
-TBW engine cover
-Eibach Pro-kit
-JL Audio
images of diagnostic screens are here:
https://picasaweb.google.com/lh/sredir? ... feat=email
all errors are congruent with the symptoms i listed above (cluster and A/C)
what is the most likely cause?
I noticed that the speed sensor is not picking up, as you can see (one of those pictures i was moving 10mph in Drive.)
could this wire possibly not be connected properly and would this cause these problems?
joe603
Car: 2014 Durango R/T
Whenever you work on your cars electrical system, always disconnect the battery!!
Check out this thread...it may help you figure out which wires you used.
http://www.nicoclub.com/archives/2009-g ... s-mod.html
timmy0257
-R2C Intake
-SBD grounding kit
-TBW engine cover
-Eibach Pro-kit
-JL Audio
joe603 wrote:Whenever you work on your cars electrical system, always disconnect the battery!!
Joe, I dont have nav on mine. and the harness you used looks different from mine. i put everything back like it was and i still have the problem. any recommendations on what i could check?
joe603
Check out the FSMs in my sig. They have wiring diagrams that show what every wire in the system.
Another option is to bring it to the dealer...just don't volunteer any info.
timmy0257
-R2C Intake
-SBD grounding kit
-TBW engine cover
-Eibach Pro-kit
-JL Audio
joe603 wrote:Check out the FSMs in my sig. They have wiring diagrams that show what every wire in the system.
i looked through the FSMs but I cannot make heads or tails of what i was looking at.
I will take a picture of what I cut and post here so you can see. i appreciate your time on this.
timmy0257
-R2C Intake
-SBD grounding kit
-TBW engine cover
-Eibach Pro-kit
-JL Audio
joe, this is the walkthrough i used. post3579016.html#p3579016
here is the image i went off of when i cut the wires.
tollboothwilley
Car: 2003 G35 Sedan w/ NAV
did your wiring harness match up exactly with the one from the picture?
if you grounded both of the E-brake wires then you created a ground-loop through them and that could be the cause of your problems. You should only have grounded the wire coming from the wire connection so that the screen gets a grounded signal. By grounding both sides you may have caused internal problems to the system or a fuse/relay somewhere.
timmy0257
-R2C Intake
-SBD grounding kit
-TBW engine cover
-Eibach Pro-kit
-JL Audio
tollboothwilley wrote:did your wiring harness match up exactly with the one from the picture?
thanks for looking at my thread, john. i opened her back up today and took a few more pictures. here they are:
if you will look at this album, one photo shops the back of the AV Unit. the screwdriver points to the connector that i modified.
the other photo shows the wires that i cut. the grey one should have been the VSS and the blue the ebrake.
as you can see, the VSS is cut short so i will need to solder this - i plan to do so when i finally get this figured out.
john, i emailed you in response to your comment about the ground loop. that is what i suspected. what fuses and/or relays could be affected?
thanks again. everyone on this board is super.
timmy0257
-R2C Intake
-SBD grounding kit
-TBW engine cover
-Eibach Pro-kit
-JL Audio
john, come to think of it, since we now know that i did not disconnect the battery when i was doing al of this (yes, i know...dumb) i remember that the A/C was still blowing. i grounded both ends of the ebrake wire then when i put it all back together it stopped blowing. then i had the problems... it must be the issue with the ground-loop.
Return to “G35 and G37 Interior, Exterior and Audio”
