danrd558 »
https://forums.nicoclub.com/danrd558-u138668.html
Wed Oct 07, 2009 6:02 am
sorry took so long to answer back guys and thanks for all the replies. I doubted that its the clutch because when i press it down it feels normal and as i said when i dry shift through the gears they all work except 1st gear. I'm not sure if the master needs fluid or not. My friend is coming over later to help me check out slave, we will also check the master as well. I never thought about the pressure plate or the lines being dry so ill check those as well. Once again thanks alot guys for all responses and i will keep u all updated.
