Help! I cant get the lip offf!
v0va
hey guys ive got all the bolts off but now i have those 4 things that ure supposed to turn with ure hand, there right by the air ducts theres 2 in each air duct, is there any way i can get them off, by the way is the lip on 95 se
entity
bolts off of what?
spoolthis
If they have a phillips head then unscrew it w/o stripping or if no phillips then you push the center through. Once the center is out you can pry the rest out.
I just got done putting the front end of my '90 back together. I doubt your fasteners are different.
Mikey240sx
v0va wrote:hey guys ive got all the bolts off but now i have those 4 things that ure supposed to turn with ure hand, there right by the air ducts theres 2 in each air duct, is there any way i can get them off, by the way is the lip on 95 se
Well if you plan on selling it once you do take it offjust name your price.
v0va
naw i gotta repaint and fix the cracks and its going back on,
96_S14_SE
Car: 96 S14 SE - 05 VW GTI 1.8t - 89 S13 coupe "gold on brown"
Your talking about the wing nuts correct.... I got mine off by hand waiting for the tow guy once, back when I put a chunk of metal L angle through my oil pan.
If you cant do it by hand, use some needle nose or regular pliers, or a slotted screwdriver between the wings. You could even use a punch or a slotted screwdriver and a hammer and get it turning that way...
There are countless ways.
Try some PB blaster on it as well first.
