NISTECH »
https://forums.nicoclub.com/nistech-u7581.html
Mon Nov 03, 2003 2:23 pm
compress the piston by rotating it clock wise while pushing it in. if you have bolted the carrier in(what the caliper bolts to) place the pads on either side od the rotor. if you have indicators on the pads they go on the inboard pad of both sides of the car. if only one pad has an indicator it goes on the right(passenger) inboard postion. once you have the pads in place and the piston compressed slide the caliper over the pads and install the bolts. note: the pin on the pad should line up with the slot on the caliper piston ,any one, just rotate the piston so it lines up.
