Torgus wrote:Thanks for the reply. The only reason i want to use these subs is i have them and got them for free. also if i sell em i bet at most i'd get $100 bucks. i want to do this build as cheaply as possible and see how they turn out. Also if it works out well i'm sure a friend will buy my setup why i'm ready to upgrade.
Sounds good and in that case I can certainly show you some enclosure options. You can then pick what you want, because who am I to tell you what size/tuning of an enclosure you should use.
Torgus wrote:Thx for the info on the amp. looks like i'll be picking one of those up.
Do know that it has XLR and 1/4" inputs. No RCA's. You may also want an eq of some sort later. There are various options available.
Torgus wrote:If i ever redo it i'll use some better woofers for sure. probably 2 15s Fi Qs or something of that nature...
The Fi Q's will work, but due to their high Qts, they require huge boxes...and I'm talking in the 15-20ft area per woofer (30-40ft combined). Which is fine if you can build that big.
Torgus wrote:edit: oh and some of the loudest SPL woofers in the world have the same Xmax as my sub. Fi BTL for instance. or here is one more SPL sub with 10 mm Xmax which is also a world record holder.. Pioneer 5000 spl.
I don't think that having a larger xmass means it will change or have a better the SQ or tonal quality of a sub with less xmass. or even more SPL necessarily...at least from readying this i dont: http://www.soundsolutionsaudio...=8375
That information is completely useless when it comes to HT. That is all about SPL competition and so are those subs. They're useless in the HT world. Here's why...
For SPL competitions, guys will "burp" at what, 50-60hz? Well for each octave you drop, you must increase excursion by 4 in order to keep the same SPL. So if you're able to hit say 105db (anechoic) at 60hz with 6mm of total excursion, you'd then need 24mm of excursion at 30hz to hit 105db and 96mm at 15hz. In the music world, bass rarely drops below 30hz. In the HT world, there are a LOT of movies with <15hz content. War of the world has a scene with a massive amount of 5-10hz content. So you tell me excursion is NOT important. This is one reason why people will use helmholtz resonators (ports and passive radiators). FYI, 0.4in of xmax = 10mm. 20mm total (peak to peak) excursion. See why I said that was a red flag?
Well for all the modeling, I had to get more TSP's from the RF website.http://www.rockfordfosgate.com...s.pdfAccording to that site, the woofer only has a little over 6mm of xmax, so that's the number I used.
Yellow = Dual RF 1812's in a 16ft enclosure tuned to 18hzPurple = Single of my CSS SDX-15 in an 11.5ft enclosure tuned to 15hz.
Here is the transfer magnatude. This is how the speaker will perform in relation to reference (-0db). For an EBS (Extended Bass Shelf) I like to stick with around a 3db drop, but I don't like a huge shelf so my enclosures typically are a bit smaller than a true EBS3.(db from reference on the right. Frequency in hz on the bottom)
This shows how much power each can handle. The flatline represents the thermal power handling, the dip indicates how much power it can handle at it's mechanical limits. Notice that because of the Fosgate's lack of excursion, even though they can handle quite a bit of power thermally, they can't handle much mechanically before pushing them past their limits. The SDX-15 hits it limit around 1kw, the twin 1812's can handle 85w safely.(Watts on the right, hz on the bottom)
This shows the amount of excursion at the point where xmax is reached for each speaker. 85w (total combined power) for the twin RF's has it reach the 6.1mm xmax, 1kw for the SDX-15 allows it to hit 30mm xmax. This also shows how below tuning, the excursion goes crazy! That's why people will use subsonic filters.
Here is the output (SPL) at 1M with no room or boundry gain with the maximum power each can handle without exceeding xmax. 85w for the RF's, 1000w for the SDX-15. As you can see the single 15 certainly out paces the twin 12's because of it's massive amount of excursion. Still believe excursion is useless? In HT, displacement (cone size x excursion) wins.
And here is what would happen if you fed the RF's with 1kw of power. As you can see they exceed xmax by 350%, which will certainly cause them to fail.
So, moral of the story is you either need a much smaller box tuned quite a bit higher and use them as woofers for music, or build them in a large box, tuned low for movies, and get yourself a 100-150w plate amp.
Or, buy the EP2500 and be super careful. Then when you're ready to upgrade, I can point you to some good directions.
