Any switched 12V would do... I think I have my ign input on the unit tapped into the power for my TPS.NCOHs13 wrote:I know this is an old topic and i apologize if there is any inconvience but i was wondering if you knew which wire is an accessory wire and which is an ignition wire in the ignition harness by the colors. I have to run an accessory and an ignition for my dif fan controller and i think i tapped the wrong ones cause as soon as i turn my key the fans kick on, which there not supposed to unless coolant is at proper temp. I cant find the ignition harness anywhere in my nissan shop manual. Thanks again and sorry for the inconvience if it is one. Car is a 92 240sx hatch
