HELP!! how to realign my front struts
All things Altima Coupe.
darkmessenger
Car: 2009 Nissan Altima Coupe 2.5s Niagra Grey
So I was trying to install my STB.. but somehow I shifted my struts holes... now I cannot see the holes at all..
How to I realign the struts????
Mr.Coupe
Car: 08 Altima Coupe 3.5 BOOSTED
Jackup the car and remove the wheel if you prefer. Grab the strut with your hand and align it with the holes. Then simply screw the screws on. VERY IMPORTANT don't forget to use jack stands :yesnod .
Ricky C. :dblthumb:
darkmessenger
Mr.Coupe wrote:Jackup the car and remove the wheel if you prefer. Grab the strut with your hand and align it with the holes. Then simply screw the screws on. VERY IMPORTANT don't forget to use jack stands :yesnod .
Ricky C. :dblthumb:
: ( I was trying that all night... but it looks like it got worse... now I cant even see the hole anymore....and it looks like the struts is so hard to move ..
darkmessenger
so it turned out I had to jack up both side of the car in order to take out the pressure on the struts assembly... I was following racingline's instruction and only jack up one side of my car lol...
guess sleeping helps, I actually dream up the solution hhaha
